Old 09-04-2003, 04:43 AM
Cobra Make, Engine: None Yet
Default 351 Block Question
When did the 351 first come with roller lifters?
auto10x
Bill
Old 09-04-2003, 06:07 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Old 09-04-2003, 07:04 AM
Mr.Fixit's Avatar
You can put roller cams into the ealier blocks too.
Old 09-05-2003, 10:39 AM
Thanks guys.
auto10x
Bill
Old 09-05-2003, 04:00 PM
Think factory 351W roller blocks were made from '93 - '95 when the W engines were discontinued.
However, all the major cam grinders make retrofit roller cams to fit any year block. Comp uses standard roller lifters and a smaller base circle cam. Crane uses shorter lifters, and a standard base circle cam. All use the standard spider to hold the lifters in place.
When retrofitting a non-roller block for a roller cam, some machine work might be necessary on the block to properly fit the spider, and clearance the back of the lifter galley for lifter and bar clearance.
Old 09-05-2003, 05:04 PM
Jack21,
Thanks for the added info.
auto10x
Bill
