SUPPORT OUR SPONSOR
February 2026
Old 09-05-2003, 02:29 AM
chuckbrandt's Avatar
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default Need Painting Info
Where is the best source of painting info for a fiberglass car? I've painted steel cars before, mostly interested in any particulars related to fiberglass. Anything I should watch out for.
Getting ready to start!!
Thanks, Chuck
Old 09-05-2003, 10:52 AM
Chuck,
Make absolutely sure that before you do ANYTHING to the 'glas, let it sit out in direct sunlight for several days and wash it very well several times with a good wax and grease remover. All fibreglass will have mold release agent on them and I can all but gaurantee you that the manufacturer did not clean it very well. You must do this otherwise you will most likely have major downstream problems. Once you do this it is little different than working with any other fillers. If you want a straight body, you will need to spend hours upon hours blocking-priming-guide coating, blocking-priming-guide coating, blocking-priming-guide coating etc... prior to final prep for paint.
Any other questions just post them here.
John
HTML code is On
