SUPPORT OUR SPONSOR
Old 09-22-2003, 02:14 AM
Cobra Make, Engine: B&B 351W
Default Pin drive adaptors
Does any one know where I could find the pin drive adaptors for a ford 5 lug bolt pattern, I would like to put my pin drive Trigo’s on the bolt on style hubs.
Bob
Old 09-22-2003, 03:55 AM
Trigo's adapters are drilled for both 5 x 4.75" and 5 x 4.5" patterns. If you need something different, Lynn may have some undrilled blanks.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 09-22-2003, 07:00 PM
Rick Parker's Avatar
If you are planning on using PS Engineering FIA style wheels they WILL NOT FIT a 5 lug pin drive pattern. Nor will they accept either of the mentioned bolt circles. The mounting pad diameter & design on the back of the wheel dictates a six pin drive system. You may want to check with Trigo to see if their new FIA wheels will allow for 5 lug design. It would take a larger diameter mounting pad similar to the 427 styled wheel they currently offer for the 5 lug adapter setup.
Rick
Rick
HTML code is On
