SUPPORT OUR SPONSOR
February 2026
Old 09-24-2003, 01:58 PM
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Default Wilwood Brakes w/PSE 15" Wheels
Hello, I currently have a Mustang II front suspension and brakes and would like to upgrade to the Wilwood brakes. Will upgrading to the Willwood setup move the front wheels in or out from the Mustang II brake setup. Also, which Wilwood setup is recommended Heavy or Medium. In additon, will the Wilwood setup allow me to use my 15" PSE wheels without any problems?
Thanks
Old 09-24-2003, 05:22 PM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
Go with the heavy. They are only like 10.75 inch diameter and will easily fit into a 15 inch wheel. The light and medium duty are more oriented for drag racing and use a solic rotor. The heavy rotor is ventalated.
Old 09-25-2003, 09:00 AM
Thanks for the Info. Do you know if this setup will change my wheel offset?
Thanks, Again
Old 09-25-2003, 09:04 AM
rdorman's Avatar
Renegade Nuns on Wheels
Your offset should not be effected. By the way, you should be able to use the 12.19" rotors.
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 09-25-2003, 09:34 AM
Thanks Rick. Who offers the 12.19 Inch Rotors? Do they come with the Wilwood heav kit?
Old 09-25-2003, 09:45 AM
rdorman's Avatar
Wilwood does. Check out there web site for the correct kit or give them a call. Find out minimum ID of the wheel and measure before you order!
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 09-25-2003, 09:50 AM
Thanks Again Rick
Old 09-25-2003, 10:23 AM
Replaced the mustang II with 10.75 heavy wilwood setup on my classic roadster,this moved the wheels out almost 3/4in.on each side,also lost 12 lbs.on each front corner.Randy
Old 09-25-2003, 11:53 AM
I can difinately deal with the weight reduction but cannot have the wheels out any further than they are now. Any suggestions? Besides changing the wheels?
Thanks
Old 09-29-2003, 10:16 AM
rdorman's Avatar
Default Double check.......
.......... with Wilwood. The wheel mounting surface should not move out bound unless more room is needed for caliper clearence. Be sure to check for clearence to tie rod, caliper to wheel, wheel weights, etc.!
I lost over 20 pounds of unsprung weight on each corner!
Rick
OhioCobraClub.com
LondonCobraShow.com
HTML code is On
