Old 10-16-2003, 09:48 AM
Chaplin's Avatar
Default Holley Adjust-a-Jets?
Has anyone used the Holley Adjust-a-Jet kit? It seems like it would be a good idea , but before I order it, I want to see if anyone has actually used it and, if so, what your impressions were?
Replica is not a dirty word.
Old 10-16-2003, 12:06 PM
Mr.Fixit's Avatar
Never seen it, what is it?
I still have an Unused Holley float bowl with removable plugs so you can change jets without removing the fuel bowls, never used that either.
Old 10-16-2003, 12:20 PM
Chaplin's Avatar
Fixit-
The adjust-a-jet kit allows you to effectively change primary jet sizes with the turn of a screw. By using metering rods instead of jets, you can change the mixture simply by turning the metering rods while the car is running. For some reason, I could not get Holley's website to work, but below is a link to someone that is selling one of the kits on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437152038
Old 10-16-2003, 12:28 PM
Mr.Fixit's Avatar
I wouldn't want it. The metering blocks are really the heart of a Holley carb, I would be suspicious getting a totally redesigned metering block. Adjusting the main jets while the car is running, why? They don't affect idle very much, so doing it while running is of no benefit. I think somebody used to sell a kit very similar, made by Percy's or something. If you could adjust it from the cockpit, might be good for Pike's Peak race, where the altitude change is great. I would also rather have a plain orafice, then adjust flow with a needle and seat valve.
Old 10-16-2003, 01:26 PM
Hotfingrs's Avatar
I've tried using them.....didn't like them. I bought the ones made by Percy, before Holley bought them out. It's not a redesigned metering block, you add this block in addition to the one already present....I tried mainly for the dragstrip...but found the adjustments to be waaaaaay off and not precise.
Jack
XSSIVE .....
