Old 10-16-2003, 11:50 AM
Default Electrical Connector ?'s
After the first summer on the road I have had a few electrical connections come lose on my Cobra.
One of my winter projects is to go through the car and check all the connections. I used the crimp on type connectors. Is there a better style or method of making connections?
Roger
Old 10-16-2003, 11:57 AM
rdorman's Avatar
Renegade Nuns on Wheels
Use the aircraft style crimp on connectors and tool. You can get them at the local airport or places like Aircraft Spruce whom you can find on the web. Don't forget put some heat shrink on each one. Done this way they will probably never come off!
OhioCobraClub.com
LondonCobraShow.com
Old 10-17-2003, 02:48 AM
Rick,
Thanks for the advice.
Roger
Old 10-17-2003, 04:16 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Default terminals
There is a company, terminal supply. I think they are in Troy MI.
They have the best connectors for automotive.
Sorry, do not have a phone number, try the net.
They have weather seal type, very nice. After you put the connector on, soldier it to the wire.
Works!
Just my $0.02
Old 10-17-2003, 07:22 AM
Rick Parker's Avatar
Default Excellent electrical supply source
www.waytekwire.com
GREAT!
PS: Rosen core solder, heat shrink tubing and plenty of time. That's what it takes.
Old 10-17-2003, 07:46 AM
take time and do it right, solder all the connections. i guarantee they will last forever with shrink sleeves. thats what i would do
Old 10-17-2003, 09:17 AM
How can I guy argue with the solder technique, it's got to be the best way. But in many cases it is just impractical.
The key to a crimp connector is using a good brand AND a GREAT crimping tool. Done properly there is nothing wrong with a crimp connector. If you want to add some heat shrink it's virtually a permanent fix.
Ernie
Old 10-17-2003, 05:21 PM
Here's what works for me on automotive wiring connections.
Automotive wiring has two enemys, 1) corrosion, 2) vibration.
The parts are basically hardware store and Radio Shack. This is a patience intensive job.
You can get bare metal connectors, or you can remove the plastic sleeve off the connectors. Removing these is important to the completed joint.
First, get some shrink tubing that will protect the joint when completed, clip a piece about 1" - 1 1/4" long, and slip it onto one of the wires to be joined.
Crimp the joint with a decent crimping tool. Then solder the joint. If soldering is impractical, than do a very good crimp job.
Coat the joint with a sealant. I use ordinary wheel bearing grease applied with a Q-tip. Vaseline (the stuff you '50's guys use on your hair) works. Spark plug boot dielectric grease will work. You just want something to keep air, moisture, and water away from the joint. A thickened WD-40 would be ideal.
Slide the piece of shrink tubing over the joint and shrink it in place. I use a Monocote gun from Tower Hobbies from my R/C modeling days. They're an electricians best friend and still only $19.95. But a good hot hairdryer will work too.
And you're done. No more pulled loose or corroded electrical connections.
Old 10-18-2003, 10:16 PM
Waytech also have Packard/Delphi weatherpack crimp on connectors. They are the type that GM uses on all underhood EFI connections. I both crimped and soldered my ends. Used them on all engine bay and out of cockpit connections. They make a waterproof, professional looking connection. Waytech also sells the crimp pliers made especially for these type connectors.
Old 10-20-2003, 09:08 AM
rdorman's Avatar
Default Soldering is not always the best
The aircraft industry 'generally' uses crimp on connectors because soldering can cause wire embrittlement and premature failure. Solder if you must but aircraft quality connectors (I use shrink tube as well) will not let you down.
OhioCobraClub.com
LondonCobraShow.com
