Old 12-03-2003, 06:03 PM
Nuke427's Avatar
Cobra Make, Engine: Gave it to Russ
Default Rocker stud girdle install
How do the rocker stud girdles install on the heads? Do they replace the existing hold down bolt on the top of the rocker? Just curious as I'm researching getting a set since I like to hang out in the upper rpm band. Thanks in advance for as much info as you care to share with me on this topic.
I wish this reactor had wheels!
Old 12-07-2003, 02:17 PM
You mention replacing the hold down bolt which makes me think you've got pedastal mount (bolt down) rockers. If so, those won't work. Gotta have stud mount.
If you do have stud mount rockers you're all set, the stud girdles come with a new set of adjuster nuts that are extra long and have a shouldered area on top for the girdle to slip over.
FFR 4447 with DOHC power in the works
