SUPPORT OUR SPONSOR
Old 12-21-2003, 07:40 AM
Cobra Make, Engine: Kirkham #259
Default Rear Sway Bars
Do any of the Various models have a Rear Sway bars that are adjustable........ different hole to stiffen... not from the drivers seat.
Are there any photo's of how the rear bars are mounted....
I'm a big believer in lower spring rates and more control with Sway bars.... but haven't seen to many Cobra's with rear end control with the sway bars....
Any drawings on how to mount a bar in the rear area?
Morris
Old 12-21-2003, 08:09 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Morris:
Check th ERA site, they use an infinately adjustable rear sway bar.
DonC
Old 12-21-2003, 05:05 PM
DonC
Thanks I'll do that.... and start figuring out a way to do it....
Morris
Old 12-21-2003, 06:22 PM
Richard Hudgins's Avatar
Cobra Make, Engine: Porsche 928 S4
Morris,
Anti-roll bars of the type that you wish are quite easy to fabricate.
Just a bit of 4130 tubing, bend in a couple of places, heat treat to 38 rockwell, fab up some chassis mounts and links and you are home free.
There are a bunch of folks in your area that can do this for you.
Try Steve Latham at Citation. Or anybody in the Indy area. You will find someone that has the capability, not a black art.
Best regards,
Richard Hudgins
Old 12-21-2003, 06:40 PM
Richard
Thanks for the info....we appreiate the heat treat info.... didn't know how much to heat treat...
And your right there's allot of stuff in Chicago...
Morris
HTML code is On
