SUPPORT OUR SPONSOR
December 2025
Old 02-10-2004, 12:49 PM
Default throw out bearing and valve cover color
hey guys
see if anyone can help here. two questions. first, can anyone guess at what might be making a rattling noise in the clutch assembly. sounds like its coming from the throw out bearing. this only occurs when the transmission is in nuetral. this is a hydraulic system, not mechanical. when shifting and in gear there is no noise. all are new parts. second, does anyone know the correct color for the valve covers on the fia 289 race engines?
paul
Old 02-10-2004, 01:54 PM
wilf leek's Avatar
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Paul - it might just be rattle from the gearbox itself - try pushing your tickover up a tad to smooth it out and see what happens.
One way to determine if it is your throwout bearing is easy - if the noise stops as soon as you put light pressure on the clutch pedal (but not enough to disengage the clutch), it is coming from the throwout bearing. If the noise keeps on until you have completely disengaged the clutch ( and therefore there is no drive to the 'box), then it is from the box itself, and may not necessarily indicate a problem.
Wilf
Old 02-10-2004, 02:43 PM
wilf
thanks for the reply. its in my sons car, so i'll pass along the info. see what happens.
thanks,
paul
Old 02-10-2004, 02:52 PM
computerworks's Avatar
Default Re: throw out bearing and valve cover color
Originally posted by paul cass
...does anyone know the correct color for the valve covers on the fia 289 race engines?
paul
A matte Silver paint.
Old 02-10-2004, 05:55 PM
Rick Parker's Avatar
Argent silver. It is or was available from Ford in a spray can.
RE the T/O bearing, it could be one of severeal things. May have had it improperly adjusted and "cooked" the grease out of it so it is now "dry".
Rick
Old 02-11-2004, 02:34 PM
thanks for the reply guys. it may be a while before my son will have time to check things out, but he's hoping that he doesn't have to remove the tranny. i'll check on the paint. the only pictures i could find for paint color were vintage shots and the color looked gray. thanks again.
paul
Old 02-12-2004, 10:51 AM
Paul..........you have mail
Rick
Rick
HTML code is On
