SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-22-2004, 08:49 AM
Tom Wells's Avatar
Question Trailer: best way to mount shelf or brackets inside walls?
Hello all,
Thinking about putting a tire rack, a shelf for the helmet etc, and maybe another shelf for oil or whatever on the inside of my Haulmark trailer.
What's the best way to fasten this stuff to the trailer's walls?
Should I go all the way through and seal the hole the way you do a boat hull, or just try to grab the 3/8 plywood from the inside?
Or maybe even try to hit the metal ribs behind the plywood?
Any "voices of experience" available here?
Thanks in advance,
Tom
Old 02-22-2004, 09:32 AM
Cobra Make, Engine: Kirkham #259
Tom
Use the #12 or #14 Hex head Screws that will drill the hole and screw into the metal studs.... but drill a 1/8th inch pilot hole first....
First I had to find a Stud and then every 16"mount the device...
Mounted workbench, Toolboxes, Nitrogen tank, Mounts for hoses and hanging clothes, lifts and jacks....
Finding the studs is the hardest and had to drill some 1/8" holes to do it.... then use RTV or a D-ring to cover the holes.... especially if it is a nice white interior....
Morris
Morris
Old 02-22-2004, 10:17 AM
Tom Wells's Avatar
Hi Morris,
Thanks! I'll go get some now.
Oh, what length turned out best? Maybe 3/4"?
Tom
Old 02-22-2004, 03:49 PM
Tom
I think I used 1 1/4" to 1 1/2" and they screwed down tight.... figure .125 for the piece and .375 for the wood wall and .125 for the stud.......
We drill a 1/8th inch hole then use another drill with a magnetic hex driver and screw it in to the stud.... .....
I would plan out what you want in the trailer before you start drilling and lay every thing out based on the stud locations....
You might want to check out
www.pitpal.com
got all kind of trailer stuff...
Morris
Morris
Old 02-22-2004, 04:45 PM
Tom Wells's Avatar
Hi Morris,
Thanks!
I'm off to order some racks, shelves & screws....
Tom
Old 02-23-2004, 09:54 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
A stud finder with a metal stud sensor should work to locate the vertical and horizontal framing --- also, though I've not really payed attention to trailer walls, I would think that there would be screw heads visible that mount the plywood to the framing unless filled and painted or fabric covered .
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
HTML code is On
