SUPPORT OUR SPONSOR
Old 02-29-2004, 04:28 PM
Cobra Make, Engine: SPF - 427 Stroker
Default Electrical Gremlins
I was out for a drive this afternoon and experienced something weird. Diring a 2-3 upshift, the motor died. There was a backfire then, NADA. Pulled over to the side and noticed the fuel pump was not running. Usually when I turn the key once, the fuel pump will start running - but for some reason it was not. Also, the fuel guage was not working and neither was the heater or wipers. I'm getting power because the horn, lights and starter all work. The motor will turn over and sounds fine (nothing internal) but it just isn't gettng any juice. The car is a Superformance. Any suggestions ??
NEVER LIFT
Old 02-29-2004, 04:42 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
You did check the fuses right? Always look for the easy fix first.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 02-29-2004, 04:43 PM
Ok - I feel like a REAL DIP$HIT - A small connection behind the dash, going into the ignition had come loose. I must have brushed it while reaching down to hit the cooling fan switch. DOHH
Oh yeah, hi again fellas
NEVER LIFT
Old 02-29-2004, 04:44 PM
An easy fix is the best fix of all!
Bruce Edwards
Old 02-29-2004, 10:34 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Don't you just hate it when things like that happen---then DUH why didn't I see that ?
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
HTML code is On
