SUPPORT OUR SPONSOR
Old 03-04-2004, 01:03 PM
Send a message via AIM to quebow03
Default Marine 427 SO???
I posted this on the "All Cobra" area and thought I might get some different viewers and/or responses here.
I have read a few things here and there from different thread regarding marine 427s. I have my eye on one or two and would like to know what could potentially go wrong using this block (assuming it was a closed system w/o salt water exposure). I have also read about how dual powered boats have both the engines turning in opposite directions. Sorry for the ignorance, but which direction should I be looking for (as I'm standing in front of the engine)? And finally has anyone actually used one of these block and/or made the necessary corrections to the cam and crank on the reverse engine? I would much rather not waste my time taking it completely apart in the bottom of boat only to find out it really isn't going to work. What should I be expecting to pay for a 427 SO block worthy of rebuilding??? I think I can get two that are in running condition for $1000 a piece... Anyway, opinions would be appreciated. Thanks
Dan
Old 03-04-2004, 05:29 PM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
Okay...there is a standard and reverse rotation. The reverse rotation has a different cam. The crank has the hatch marks for oiling the rear seal in a reverse pattern. The hatch marks or oil grooves can be ground smooth to use the crank if not the rear seal will leak. I think the oil pump and water pump are setup for the reverse rotation also. The heads are low riser type. The crank and rods are std 390 type. The marine blocks are very good if not corroded by salt water. They are cast as a sideoiler but drilled for centeroiler applications. It's really not advised to try to drill it for sideoiler use as some have the sideoiler hump ground down a bit to clear the marine motor mounts and it's a MAJOR PIA to drill. If you are only looking to purchase one get the standard rotation engine. Depending on how and what you will use the engine for you might only end up using the block. If your doing a budget build look into them as you can use most of the engine to rebuild for a nice stock runner. Upgrade the cam and valve train also. So it really boils down to what you want to build and want to spend. $1000 to $1500 each is the going price I see. Check the block for overbore and feel out the seller for info. Are they in running condition in a boat....how many rebuilds? etc..... Let me know what other info your looking for. I can give you some part numbers if needed to verify things. Email me directly if you like. Glenn.
HTML code is On
