SUPPORT OUR SPONSOR
Old 03-06-2004, 07:26 AM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Question Ignition Wire Crimper and Stripper
I am in the market for a new Ignition Wire Stripper and Crimper for my FE engine. I am using 8.5mm wires.
Is there a standout set of combined crimpers and cutter/strippers that I should consider over all others? I would like to buy one of the best tools in this category.
Where should I look? Brand suggestions and use reports are welcome.
Thanks in Advance Amigos.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
Old 03-06-2004, 07:39 AM
PatBuckley's Avatar
MSD sells what you need - available through Summitt - works as it should.
Make sure you use the double crimp, positive locking terminals.
Old 03-06-2004, 08:40 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Besides MSD---Ancor also makes them---from hand crimps to hammer style for up to "0" wire.
FWIW--Ancor's basic wire/stripper/ crimper tool is the best I've ever used IMO, for wire up to 10 gauge. A bit pricey but even better than the Kliens I have
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 03-07-2004, 05:39 AM
Thomas Gayer's Avatar
Cobra Make, Engine: B&B 66 427W Roadster
You should ONLY USE a ratchet positive squeeze type crimper for any insulated or coated connectors if you want to be safe.
The old mash it type Kleins are wonderful for non insulated sta-kons if you use heat shrink to insulate.
You can get one of these green handled ratchet at electrical supply house. Tell them you want the kind that are used in Chemical Plants etc.
Tom
SSSSSSSSSSSSS
Old 03-07-2004, 07:46 AM
Cobra Make, Engine: Midstates, Genesis 427 S/O
Thumbs up
Art,
Use a coax ratcheting crimp tool kit. Greenlee and T&B both make them, as well as numerous other companies. You might try WW Grainger, or any electrical wholehouse. Stay away from the old mash type connectors, loose connections build heat. Heat is electricity's #1 enemy. If you can't find them, send me a private message. I'll get you a catalog #.
Chris,
slithering
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
HTML code is On
