Old 03-06-2004, 07:40 AM
Cobra Make, Engine: Lonestar / 408W Stroker
Default fuel lines?
Steel or metal?
HMIHNTR
Lone Star LSC427, Speed-o-Motive 408 Stroker
2005 Ford SD 6.0 Harley Davidson /Super Chip 425 HP
1975 24' Campbell V-Drive / 1963 427 Ford
2000 Prowler 32' 5th wheel
And the Harley pulls them both to Lake Havasu
Old 03-06-2004, 06:42 PM
Cobra Make, Engine: E-M , 5.0 efi
I used the larger size break lines. Figured if it could handle the preasures of a break system, fuel would be no problem. Also easy to find fittings.
Old 03-07-2004, 08:10 AM
Roscoe's Avatar
I used all -8 AN fittings.
Roscoe
Roscoe
Old 03-07-2004, 10:47 AM
lineslinger's Avatar
Roscoe ,
Do you have a website address for AN fittings?
lineslinger
Old 03-08-2004, 06:48 AM
Roscoe's Avatar
AN fittings, and the stainless braided hose that goes with it, can be had from any of the racing parts places:
Summit Racing
Jegs
Pegasus Racing
Everyone Else
You can also find it in your local speed shops.
The stuff is made, basically, by:
Earls
Russell
Aeroquip
With Aeroquip being the best quality IMHO.
Roscoe
Roscoe
Old 03-08-2004, 07:10 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I used Stainless with aircraft fittings.
Went right up to the engine and then Earls SS flex line to the block.
Just my $0.02
Old 03-08-2004, 11:49 AM
Thank you for the info fellas
Old 03-11-2004, 08:26 PM
steel is a metal
Mike H
Old 03-12-2004, 09:51 AM
Dominik's Avatar
do not use copper "metal", it will get hard under vibration and crack - well, that's what I heard.
use aluminum, 1/2" OD for strong motors
with fuel-injection make sure your retuen line is also big enough - not 5/16"!
Dom
