Old 03-14-2004, 12:52 PM
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
Default Lucas Oil Additive??? Help here!
I've been told to add half a bottle of this to my diff instead of fords friction modifier...is this true? should i even bother putting this stuff in my diff? how about the tranny and/or engine?
many thanks!
Old 03-14-2004, 04:38 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
I would stick with the Ford Posi lube. It is made just for Posi units. You did not say what kind of Lucas fluid you are thinking of using.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 03-15-2004, 08:41 AM
Mr.Fixit's Avatar
don't put it in, use Ford's additive for limited slip.
