SUPPORT OUR SPONSOR
Old 03-16-2004, 08:15 AM
Cobra Make, Engine: Kirkham, 482 Shelby / TKO 600
Default 5 Speed in a Kirkham
Has anyone one installed a 5 speed in a Kirkham? If so, do you have any advice?
Old 03-16-2004, 09:53 AM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Rottie, I'm using a Tremec TKO 600, the gear ratio is a lot friendlier than the TKO 2. You will have to move the tranny mount, not a big deal though.
Al W.
Old 03-16-2004, 11:23 AM
Did you need to modify the bellhousing? I am thinking of using a TKO 600 like you have.
Old 03-16-2004, 11:50 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Al:
Anxiously awaiting my TKO600 (and the car which should be finished in a couple of months). What's your opinion of the 600?
DonC
Old 03-16-2004, 02:04 PM
Cobra Make, Engine: KMP329 w/KC489 Shelby
I thought there was someone who put a TKO in a Kirkham, but it involved cutting and re-welding a cross-member. I forget the name of the member, but he had pictures and I believe Chris Kincaid (corrected) from CSXINFO built the car for him. If this is not necessary I would like to go with a TKO 600 as well. The new gears make it ideal and there is a group buy going on.
Old 03-16-2004, 02:37 PM
thorconstr's Avatar
Rottie, We are using the new McLeod scattershield, clutch & throwout. The mounts are the same as the TKO 2.
Don C., I am waiting patiently for the TKO 600 to come in (Patience hell, I'm going to kill something). My opinion is based only on the added torque and far better first gear, the 327 first in the TKO 2 was good for pulling stumps.
Dreamer, Yes the cross member had to be cut & repositioned, Premier Motorsports did that for me when they painted the car along with a myriad of other things. I put the car on a lift when it was shipped to me and I could'nt tell where the cross member had been originally.
They do some class work!
Al W.
Old 03-16-2004, 03:41 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Originally posted by The Dreamer
I thought there was someone who put a TKO in a Kirkham, but it involved cutting and re-welding a cross-member. I forget the name of the member, but he had pictures and I believe Chris Kane (I think) from CSXINFO built the car for him.
Here's what was done to the frame to get the TKO mounted.
BTW...it's Kris Kincaid
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 03-16-2004, 07:09 PM
Al,
Did you have to move the cross member back past the tranny tail or did you cut into the member as in ST's. Looks a little more than I would like to get involved with initially. I think I will let you guys blaze the TKO 600 trail and I will stick with the trusty old toploader for know. I will put the TKO 600 in my P3I (Pre Planned Product Improvment) Plan along with TWM injection and soft top.
HTML code is On
