SUPPORT OUR SPONSOR
Old 03-16-2004, 08:48 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Default Temporary rivets
What are those temporary pop rivets used to layout and fit aluminum panels called. They have a long stem that sticks up.
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 03-16-2004, 08:50 PM
computerworks's Avatar
cleckos
Old 03-16-2004, 08:53 PM
joea's Avatar
Yup they are the ones...hopefully I can find them at Summit now! Thanks. I have the fun job of installing my own aluminum trunk panels!
Old 03-17-2004, 04:45 AM
C-L-E-C-O
Aircraft Spruce
Old 03-17-2004, 04:51 AM
joea's Avatar
Thanks Bob...is it 1/8" fasteners for the trunk panels? Aircraft Spruce is quite a bit cheaper than Summit.
Old 03-17-2004, 05:55 AM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
You can purchase from Eastwood www.eastwood.com cheaper than most locations I have found and then ya get tons of catalogs for life >>>>>>
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
rdorman's Avatar
Renegade Nuns on Wheels
Aircraft Spruce is a great resource. Get their catalog. Glad you are getting the Cleco's. Don't try a rivet job without them! Remember, all rivet are not created equal. The all around best used to be the 'cherry' rivets (DON"T go to the hardware store for them). I may have just dated myself with that comment! I am from the school of fastner overkill. AN/MS stuff is just right for me. Lock washers are evil, safety wire is our friend
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 03-17-2004, 07:44 AM
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
You can also get them through Finish Line...or try some of your local speed shops, theres one near me that sells them so you might have some luck with that.
Old 03-17-2004, 03:21 PM
Originally posted by joea
Thanks Bob...is it 1/8" fasteners for the trunk panels?...
The aluminum trunk panel rivets are all 1/8" diameter. We only use 3/16" (large head) rivets to secure the fiberglass.
Old 03-17-2004, 08:58 PM
Club Cobra Member
Cobra Make, Engine: SPF
Send a message via AIM to Tinker51
Exclamation Pliers too
If you are going to get some clecos don't forget to order the special cleco pliers too.
We have enough youth. What we need is a fountain of common sense
HTML code is On
