Old 04-04-2004, 03:55 AM
Cobra Make, Engine: De-type
Default Alternator rattle
Alternator rattle at various seeds. Using 40mm Gilmer in a 3 pulley system on 302 Windsor with clockwise water pump. Have setup the alignment to within 1 or 2 degrees in both vertical horizontal plans, a times I can see the alternator fan wobble. I can not feel any movement in the alternator bearing and it spins well. it is a new Bosh unit. I have used a genuine cast bracket on the head that puts the pivot between the two head fittings that lines up with the front bracket normally used on a Cleveland.
Old 04-04-2004, 05:36 AM
Atomsk's Avatar
Cobra Make, Engine: None in real life (Kirkham slabside 289 in my dreams)
Send a message via AIM to Atomsk
I had the same thing happen to a supposedly new alternator once. Turns out the front bearing was in the process of eating itself all along. I wound up replacing the bearing myself, it only took an hour.
Call around, you should be able to find a replacemnt bearing for a decant price.
Brian E Clough
"No user-servicable parts inside", I'll be the judge of that!
Scientific discovery doesn't sound like "Eureka!", it sounds more like "huh, that's funny...".
Old 04-04-2004, 05:58 AM
Rick Parker's Avatar
Sometimes the fan will begin to rub on the alternator housing if it is not sandwiched tight enough between the pully and spacer. Check the tightness of this with a box end wrench and a hex wrench or hex socket (best). Otherwise as mentioned check the front bearing.
You mentioned Gilmer belt, do you mean "toothed" belt ? If so, the pulleys need to be aligned perfectly or there will be l harmonics transmited by irregular tooth engagement.
