Old 04-13-2004, 08:00 AM
Question Smaller clutch slave cylinders?
Does anyone know of a 5/8 or 11/16 bore slave cylinder to use? It's for a Tremac 3550 that has a push type held on by 2 side bolts. So far the only possibility I've heard of for a 5/8 is an early spitfire but I'm not sure of the mounting.
Old 04-13-2004, 12:08 PM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
I just installed the slave cyl on my backdraft. I would guess it had about a 11/16th bore and mounted with two bolts{prox 1/4"} to an ell bracket with a hole in it for the adjustment rod to go through. That whole assm bolted to a horseshoe bracket on the bell housing. Look at the picture on the home page {clutch bracket by boudy} You may contact Backdraft to see about buying one.
hope this helps
Old 04-14-2004, 07:05 PM
what brand of master cyl are you using?
Mike H
