Old 04-23-2004, 06:18 PM
Cobra Make, Engine: In Limbo for the time being
Default Which gears????? 355 or 373
Ok, an area I am lost in,even reading these old posts. I have a t-5 tranny from a 90 mustang . EFI 5.0 guessing with about 350 to 370 +or- hp. I will be running 295/50/15 and a posi rear .So which gearing do you guys recommend I go with for this combination the 355 or the 373. I will not be doing any racing ,just cruising , back road driving, highway driving and playing games . I would like a good all around gear , that will be fun down low for back road driving but so I can also cruise with it on the highway .so lets here your opinions what are the differances between the 2 gears .
Thanks for the help Chris
Old 04-23-2004, 07:11 PM
You wont notice much difference in either, their both fairly close. Your engine sounds like it is a great setup and with the T-5 which has a nice overdrive 5th I would go with the 3.73s. The only way I would not recommend the 3.73s is if you had a stock cam, this would put most of your power at a lower rpm and the higher rear would put you right outta your power band. If you have a bigger cam which it sounds like then go with the 3.73s but the difference between the two is neglegible.
Barret-Jackson + Rich idiot = Ruined hobby
Will the last rational adult to leave mexifornia please turn the lights off.
Old 04-23-2004, 07:20 PM
Cobra Make, Engine: Johnspeed,408W,Tremec 600 roadrace, Liquid Yellow w/Black stripes
Unhappy
???????, I'm missing the point.
