SUPPORT OUR SPONSOR
Old 04-28-2004, 05:01 PM
Question Knock-Off Hub screws
Hi, I have a set of 16 inch, 5 stud, Compomotive wheels with artificial knock-off hubs. When I removed the knock-off hubs, I boogered up a couple of the allan wrench screws that hold them on. Does anyone know where I can get some replacement screws for the 3 bar knock-offs??????? The screws look like they are 1/4 inch 24s but are probably metric. Local folks say they have no idea. Help if you can. I sure will appreciate it.
Pzazz03: --
PZAZZ
Old 04-28-2004, 05:22 PM
Cobra Make, Engine: NAF replica, 351W, about 420 HP
Any good nut/bolt/screw seller should help you out. Also try Compomotivewheels.com for info.
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
Old 04-28-2004, 05:24 PM
Rick Parker's Avatar
1/4" X 24 TPI setscrews are pretty common. Check yellow pages for industrial suppliers in your area, or call a machine shop, sometimes they keep this sort of stuff for their own projects. They can probably be drilled and tapped any size close if it actually is metric to begin with.
Stainless set screws are also available at marine & boat supply outlets.
Rick
Rick
Old 04-28-2004, 05:26 PM
hog hog is offline
Cobra Make, Engine: Shell Valley 351W Tremec 2004 Cobra SVT Convertible
Try this web site. They have about anything you can imagine for hardware. The ones in my wheels are stainless.
http://www.mscdirect.com
Hog
HTML code is On
