Old 06-28-2004, 10:56 AM
Thumbs up front upper control arm question
quick question...when installing the upper control arms...running a 351W with about 500hp...should the control arms be set up in the forward mounting position or the back moutning position...and how much of a difference will it yeild??
Thanks for any help!!
Old 06-28-2004, 12:18 PM
Clois Harlan's Avatar
clk2,
I think they should be set up angled to the rear of the car. I will double check tonight. What brand of tubular A Arms do you have?
I know there is a left side and a right side.
Clois
"Let's roll"
"Be part of Something Good
Old 06-28-2004, 06:16 PM
thanks for the reply..i am using the factory five upper arms that came with the kit...they say there is not a left and a right??
Old 06-28-2004, 07:46 PM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Default POLE POSITION
clk2,
The outer holes are for street use while the inside holes are for racing to allow "extreme negative camber" and slicks to help on the suspension setup.
POLE POSITION manufacturers the upper arms.
grumpy
