SUPPORT OUR SPONSOR
Old 07-01-2004, 05:16 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Default SPF Sidepipe Removal Question
After I remove the 8 bolts holding the sidepipe to the exhaust header and the 1 bolt attaching the sidepipe to the body, can I assume that it can be removed with no trouble? The car is not on a lift.
Bob
Old 07-01-2004, 05:49 PM
Cobra Make, Engine: Superformance #1374 with 392 RDI Stroker
Yes, just make sure you have someone to help you ease the pipes out of the opening. A two man job for sure.
Hope this helps
Mark
Old 07-02-2004, 08:14 AM
Mr.Fixit's Avatar
You gotta get the car up in the air a little bit, the pipes slide out at a downward angle. Use new bolts and nuts when reinstalling.
HTML code is On
