Old 07-14-2004, 09:19 PM
Cobra Make, Engine: B&B
Default sound in 9" rearend
I've got a tremec 5 speed and a 9" limited slip with 3.50 gears, if I put the car in reverse and let the clutch out, as power engages, the rearend gives me a sound like a hammer hitting the case, it only does it once as the driveline starts to turn and then it sounds fine, it seems to be worse when I engage the cluch fairly quickly, is this normal?
Terry
Old 07-15-2004, 02:17 AM
Cobra Make, Engine: Antique & Collectible 351 windsor bored and stroked tko tremec
hi terry have you had the car up on a lift? sounds will carry in drive lines but i would definently get it checked. if u have it up on a lift and put it in gear maybe it will be much easier to pin point it good luck Neil
Old 07-15-2004, 06:38 AM
I've ended up making an appointment with my mechanic who set the tolerance on the gears to let him figure it out, no sense screwing it up myself, it gets too expensive
Terry
