SUPPORT OUR SPONSOR
Old 08-02-2004, 04:28 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Motor Mounts 460ci
Before answering, take a look in my gallery to see a picture of what I need.
With that said......
Anyone know where to find correct/useable motor mounts to fit on this?
Tried the usual spots, but to no avail......
I'm not busy because I did it right the third time . . .I think!
Old 08-02-2004, 06:53 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
I really can't tell what you have, even by looking at your picture. It looks like part of it might need to be welded to the frame, and maybe not for a 460 at all. A 460s' motor mount can be had at any auto parts store. Also, a 460s' mount has three holes that mount to the block, and then two holes on the other side in which a long bolt passes through to then be bolted solidly to the chassis. I don't know if this helps any, but good luck anyway,
Tim
" It ain't no big deal"
HTML code is On
