Old 10-20-2004, 11:06 AM
Cobra Make, Engine: Unique FIA 351 W
Default Aluminum flywheel question
Does switching to an aluminum flywheel have any effect on the overall balance of the rotating assembly? would a different damper be required, perhaps?
Allen Caskie
Old 10-20-2004, 11:23 AM
I have been led to believe no to both of your questions, as long as you use the same weighted flywheel that the assembly was produced with. 28oz or 50oz.
I have been also led to believe that an Aluminum flywheel will allow quicker revving.
Anyone else?
Old 10-20-2004, 12:27 PM
flipper35's Avatar
You won't need a new damper, but if you had the engine balanced it is a good idea to have the flywheel balanced also. If it is just factory balanced you just need to make sure the flywheel is the same type of balance, internal or external.
Brent Dolphin
Old 10-20-2004, 12:34 PM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Oh No Al, this billet thing that you're on has no end to it eh?
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 10-20-2004, 12:51 PM
Clois Harlan's Avatar
The Aluminium Flywheel is great. John is absolutely right, your engine will rev much quicker and crisper and no you don't need to buy a new balancer (but it is a good idea if your's has cracks in it or apears weathered).
Clois
"Let's roll"
"Be part of Something Good
Old 10-21-2004, 07:25 AM
Thanks to all for the input.
Jim,
It's not for me. I'm inquiring for a friend.
Allen Caskie
Old 10-21-2004, 10:15 AM
mickmate's Avatar
Default wooooow doggy
Bear in mind they rev quicker in all applications. If you considerably lighten your rotating mass it accelerates/decellerates easier. When you bang it down a gear to slow the car it will now try and speed the flywheel (engine RPM) up. We have seen this on SCCA beemers where they over rev and bend valves on a downshift with a light flywheel. The other thing flywheel weight helps with is a drag or standing start. In a light car like a Cobra it shouldn't be an issue but in a Galaxie.........
Cheers Nick
mickmate
http://www.actoncustom.com/
Old 10-21-2004, 12:47 PM
Cobra Make, Engine: SPF Anniversary #1989. 427 Roush.
What is the weight difference in a standard steel flywheel and aluminum? (351)
Bruce
713-922-4801
LIfe's journey is not to arrive at the grave in a well preserved body, but rather to skid in sideways, totally worn out, shouting..."Holy sh__,.......what a ride".
Old 10-21-2004, 01:41 PM
DAVID GAGNARD's Avatar
My aluminum flywheel weighs in at 15 pounds,but it has a steel insert where it contacts the clutch,the ones without the steel insert weigh 13 pounds,I have only weighed one stock steel flywheel and it weighed 30 pounds,but I would guess 30 pounds to be the average for stock factory steel flywheels............
DAVID GAGNARD
Old 01-02-2005, 02:27 PM
Ken Williams's Avatar
Cobra Make, Engine: RUCC 331ci, Tremek, 9"
with an aluminum flywheel,,isn't the initial mass lighter? I mean with the lighter wheel the intertia is less and it is easier to stall the engine upon takeoff??? (less rotating mass)
Old 01-02-2005, 02:54 PM
Zoom This's Avatar
I have an 18 lb. aluminum flywheel in my 418 stroker and it has worked out just fine for me. Yes, the motor does rev quicker....what's not to like about that?? Also, when you are up high in the power band and you back off the gas, it's like someone appiled the brakes on deceleration. Real nice when you're dicin' it up thru the curves.
Old 04-08-2005, 05:25 AM
got snake?'s Avatar
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Will aluminum flywheels warp under normal driving conditions? I bought one and am now asking this question. But hey better now then never.
Sid
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
Old 04-08-2005, 08:16 AM
FWIY, weight saving on a car:
One pound of rotating weight is worth three pounds of static weight in terms of performance. Add some light weight tires and wheel and get a carbon drive shaft while your at it!
