Old 10-22-2004, 10:52 AM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Ford Starter Solenoid . . . Wiring?
Either I have a bad ground or I am doing something wrong here.
Anyone know the correct wiring to and from the starter solenoid, and correct me if I am wrong here, it must be grounded?
Thought I had it wired and grounded correctly, the solenoid clicked but the starter did not turn over, and yes it is a brand new battery.
Anyone . . . . . please help with the wiring!
I'm not busy because I did it right the third time . . .I think!
Old 10-22-2004, 12:02 PM
Cobra Make, Engine: B+B 351w #112
Do you have grounding straps from the engine to the frame? Jim
Old 10-22-2004, 12:33 PM
BPWilliams's Avatar
Cobra Make, Engine: none
Default wiring....
OK let's see... Battery plus goes to big lug on starter, and key wire goes to solenoid, engine is grounded to frame, negative from battery goes to frame. Turn key moves solenoid into flywheel and starts motor turning on starter. I am not sure if you have a starter solenoid that is mounted somewhere besides on the starter.....? Have you tried to short out the starter with a remote starter switch? It could also have a flat spot on the armature of the starter itself.
I hope that helps,
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
Old 10-22-2004, 05:24 PM
Cobra Make, Engine: Venom 427 351W 425h.p.
THE ENGINE M U S T BE GROUNDED!!!! I know because I screwed around for a week (and two starters) . I knew the engine needed to be grounded eventually but did not think it made a difference just to start it up..................wrong!!! Ground the motor to the frame.
Old 10-22-2004, 05:48 PM
Don't forget that even BRAND NEW solonoids can be bad. I found THAT out the hard way long ago.
