-   Shop Talk (http://www.clubcobra.com/forums/shop-talk/)
-   -   Superformance Side Pipes (http://www.clubcobra.com/forums/shop-talk/58262-superformance-side-pipes.html)
Karl Muller 10-25-2004 11:13 AM
Can anyone suggest a way to make the side pipes less restrictive. Is there a way to remove part of the glass pack.
Thanks
RedBarchetta 10-25-2004 12:38 PM
I'm curious to hear from other SPF owners that have considered/done the same. I'm sure the answer we'll hear is "Sure! Just take them off and cut them with a carbide cut-off saw. Remove the innards, then weld them back up."
Of course, that will entail a return to the Jet-Hot coating lab. But I'm thinking about going this route as well.
-Deano
newmexico 10-25-2004 12:41 PM
Sorry- LOL :LOL: :LOL:
Karl Muller 10-25-2004 12:50 PM
What I'm going to do is this:
1. Take them off
2. Cut them with a cut-off saw
3. Remove the innards
4. Weld them back up
5. Have them coated!!!!!!!!!!!!
"Striker"
newmexico 10-25-2004 01:09 PM
:D :D LMAO Please post the results if you do it. I'm such a newbie (and dumb $hit), I didn't think they were packed with anything.
You could shorten them. I've seen some with only about 1' or so on the horizontal after coming thru the fender. ??
Godzila 10-25-2004 01:12 PM
That was good:LOL: :LOL: :LOL: :LOL:
Or you could do like we used to years ago, with glass pack mufflers take them off, pour some gasoline in them and throw a match in , and burn them out!
Disclaimer:Note this post is not intended for immature audiences
%/ **) **) **) :eek: :JEKYLHYDE
Karl Muller 10-25-2004 01:13 PM
Side Pipes
Deano,
I hope we hear for other SPF owners ...as I really don't want to cut these things up
Karl
MidOHasp 10-25-2004 01:14 PM
As an aside, my jet-hot coating is junk. It's pitting and bubbling and it looks like hell. I'm considering yanking the pipes off and having a custom set of swappable "shorties" made up.
Here's an idea on how to make them louder without doing the "take them off, cut them with a sawzall, etc......" method.
Drill a series of 1" holes on the bottom of the tube directly behind the 4-into-1 and in front of where the muffler begins. Drill as many holes as possible. Then, take a piece of sheet steel and weld it in the end of the pipe, closing it off. Now, you have re-routed the exhaust gases directly out the pipe before the glasspack.
For a nice tasteful look, you could weld in however many individual 1" pipe turnouts from the holes you've drilled.
It would certainly be unique!
Karl Muller 10-25-2004 01:19 PM
A friend mentioned the Gas Burnout method...
Sounds good to me...
Someone try it and let me know how it worked!
Karl
tyfaim 10-25-2004 01:21 PM
titanium pipes
I have a good friend that is making up some titanium side pipes for his SPF! I beileve they will be slightly shorter. I will ask him to post some details.
Clois Harlan 10-25-2004 01:35 PM
Good Idea Karl!
1. Take them off
But here is another thought--run about two or three tanks of 110 octane and you may not need to do all that.
Clois
Tout 10-25-2004 03:04 PM
I had just reciently replaced my headers and sidepipes with a set from southwest Performance, what a difference in sound they make, what a cobra should sound like , as for performance I will be getting on a dyno in a few weeks. I have had two SPF cars and my first {#400}was much louder than my second, they may have changed thru the years to be more friendly on the roads. You can buy just the sidepipes if you want, contact Darrell Ratchner.
Tout
RedBarchetta 10-25-2004 03:39 PM
Originally posted by Tout
I had just reciently replaced my headers and sidepipes with a set from southwest Performance, what a difference in sound they make, what a cobra should sound like....contact Darrell Ratchner.
Tout
Tout, do you have a web URL or phone number to share? Thanks!
-Deano
Tout 10-25-2004 04:03 PM
His E mail should be dratchner@comcast.net
Tout
RedBarchetta 10-25-2004 04:19 PM
Thanks!
Dave Rodak 10-26-2004 06:15 AM
Southwest Performance
Darrell Ratchner
1613 Antonio Dr. NE
Albuquerque, NM 87112
505-298-7709
See this thread:
Thread on SS Pipes & Headers
Tim Brewer 10-26-2004 07:25 AM
If your sidepipes are glass packs, they will completely blow out in a short amount of time anyway. Then you'll have to wear ear plugs for every ride or get used to your ears ringing.
Tim
RedBarchetta 10-26-2004 07:29 AM
Dave, thanks for the link.
I'm going to contact Darrell later today and ask him a few more questions. The header cost is "reasonable", but the sidepipes are a bit too steep for me now. I might end up doing a mix-and-match for starters (his headers only) and modify the factory sidepipes for more "bite". :D
Karl Muller 10-26-2004 09:11 AM
Glass Packs
Tim
I am assuming they are glass packs. The car has 8300 miles on it.
If they were going to blow out (especially the way I drive) they should have blown out by now.
Karl
Karl Muller 10-26-2004 09:14 AM
Red,
Let us know after you call...please
