Old 10-30-2004, 09:10 AM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
Default Mocal Oil Cooler
Anybody out there have any opinion on the Mocal oil cooler sold at finish line?
The fittings are 10an... is that big enough to avoid restricting flow in a 351W?
If I can see you, I'm too close
Old 10-30-2004, 09:29 AM
PNJSNAK's Avatar
Cobra Make, Engine: A&C 427S/C, 351W, T5
MrMagoo: Been running mine for about 2 years, 5k miles. No issues, after installing noticed oil pressure rose about 5 to 10 psi at speed (40 psi). Do not forget to add an oil thermostat in line with the cooler, Mocal makes a very nice piece. The thermostat has a 180 degree operating temp mark. It will not let oil to the cooler unless it is higher than that.
OhioCobraClub.com
Old 10-30-2004, 09:39 AM
MrMagoo's Avatar
Thanks for that info. I am going with the Canton thermostat.
How do you run the hoses? In particular, the one that goes left as you are looking at it. Do you route it over the engine?
Old 10-30-2004, 09:41 AM
Roscoe's Avatar
I've got 21k and over 4 years on mine. I'm also using the Canton Thermostat with -10 AN lines.
Roscoe
Roscoe
Old 10-30-2004, 03:48 PM
Smile
MrMagoo,
Most oil cooler assemblies act in parallel to the main system. even if it clogged 100% you should still be o.k.
Steve
All my ex's live in Texas
