Old 01-15-2005, 06:30 PM
Default cold weather performace
I took the car out today , it ran good but noticed if I hit the gas hard it broke up some just after the acc shot . How does the cold air change the mix ? Would it make it lean?
Old 01-15-2005, 10:26 PM
I would think it would lean it out some. Know how you use the choke to get cars going in cool weather?
Mike H
Old 01-16-2005, 04:19 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Probably ice from the venturi....This happens a lot in cooler wx with outboard motors??
My $.02....
Coosawjack
Old 01-18-2005, 10:57 AM
Cobra Make, Engine: SPF 974
Hi John,
I have found ice in my venturi and it became stumbly, especially at idle , then I pulled the air cleaner off and saw the ice. As far as jetting........I would venture you could use at least one jet front/rear if you are out in 30-35 degree temps when the motor is tuned to run 75-85 degree summer temps. 50 degrees is a real big spread but I am not sure it would cause breaking up on the way up. If you needed 2 jets front/rear you may hear it breaking up slightly up top and near the redline. I am not sure if your symptoms are from the cold unless you are already on the lean air fuel mix borderline. Gotta get the scarf and go out again there fella !!
Old 01-18-2005, 12:45 PM
flipper35's Avatar
That's why small planes have a carb heater too. The temp drop and drop in air pressure going through the venturi is ideal for forming ice.
Brent Dolphin
Old 01-18-2005, 12:53 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Colder air = dense air = leaner,... not necessarily too lean, but yes, leaner. I'm not saying that's why your breaking up, I'm just saying...
