SUPPORT OUR SPONSOR
Old 04-08-2005, 02:31 PM
Default Holley Fuel Pressure Regulator Questions
Questions.....
1. This has (3) NPT ports.....it looks like the bottom port would be the input....the left and right ports would be outputs....the casting marks are hard to read....Anyone know if this is for sure correct?
2. The mounting bracket holes have two problems....The first one being the holes in the regulator itself are not tapped. What they expect you to do here? Tap them yourself or just stick it on with chewing gum? The second question is how in the world are you supposed to mount this bracket to anything? The holes are so close to the body of the regulator itself that I don't see any room for bolt heads or nuts.....
3. I don't see any part #'s cast into it....is there anyway to be sure if I got the right regulator before I install it? They make two regulators....one is 1-4 psi, the other is 4-9. I ordered the 4-9 psi.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 04-08-2005, 02:35 PM
OK...I just figured out part of #2....I had the bracket upside down....the flange that actually mounts to the firewall, footbox, etc...points downward. Duh.
Still haven't figured out while the holes aren't tapped though.
HTML code is On
