SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-20-2005, 10:34 AM
CobraEd's Avatar
Default False Expectations???
I have a 95 Oldsmobile Aurora which was my wifes new car and is now our "spare" car.
The car started up and ran fine the last time we used it. that was between 3 and 3.5 months ago. The battery is now totally dead after sitting for that period. The things in the car that I can think of that are "always on" are:
Alarm
radio station memory
clock memory
remote entry reciever
Main engine computer (ECM)
Are these things enough to drain a good battery over three months or so? The battery is somewhat old, would a new battery maintain charge this long, or am I asking too much for any battery.
If I am expecting too much, I will get one of those solar chargers and leave it sitting on the dash.
WADDAYOUGUYSTHINK?????
Ed
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 04-20-2005, 11:06 AM
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
I have a 97 Toyota Supra and if I let the car sit for about 3 months the battery is dead (this is with a fairly new battery). I either make sure I drive the car about once per month or hook up a battery tender. The ZR-1 Corvette will also run the battery down within a few months if not driven. I think this is due to all the alarm etc. on the newer cars. I can leave the Cobra and 52 Chevy for a long time without running down the batteries.
Old 04-20-2005, 11:46 AM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
Doesn't surprise me a all.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 04-20-2005, 12:02 PM
need4speed's Avatar
Cobra Make, Engine: Beck Lister-Corvette
Is the battery still good once it is charged? I have seen many a battery go bad with shorted cells after sitting with little use over long periods of time. If it is still good, then a trickle charger or solar charger would be a good idea. another alternative is to consider a gel cell which seems to hold up better over long periods of non-use.
Racing in a straight line is motorized bowling.
Taking corners (on a track) is a real sport.
Old 04-20-2005, 12:10 PM
CobraEd's Avatar
I havn't had time to charge it or do anything with it yet. Maybe this weekend. I think, no matter what, I am going to get a solar trickle charger and leave it on the dash.
________
________
Old 04-20-2005, 01:50 PM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
My battery manager will supply up to a 2A trickle charge if needed to maintain the battery state.
I've got an Optima in the little red car and it has a 44Amp/Hour rating. That means that it will supply 44 amps for an hour before becoming discharged.
The trick is to gain 2 pieces of information.
1. What is the amp/hr rating of your battery. That doesn't mean CCA or any of the other values that manufacturers and sales outlets throw around but the amp/hr rating. You may have to dig a little to find it.
2. What is the draw on the battery of those items that are "always on". With a chaged battery in place simply hook an ampmeter (radio shack cheapy works fine) in line with the positive cable of the battery between the + post and the cable end. You will probably get a value in miliamps - 0.0xx or 0.00x (thousandths of an amp)
Take the mA rating and divide it into the amp/hr rating of the battery and you'll know how long the always on static drain on the battery will take to deplete its charge.
In my case I have a 0.03A always on static drain on my battery and, at 44 amp/hr it will take 1466 hrs (61 days) to drain the battery.
DonC
Old 04-20-2005, 10:14 PM
clayfoushee's Avatar
Cobra Make, Engine: Unique, 427SO, it runs
A $29 Battery Tender at any decent car store can solve all your problems.
Clay
Old 04-20-2005, 10:31 PM
Cobra Make, Engine: FFR 302 bored 306: 370HP
Send a message via AIM to phatry5
Also, with it being drained all the way down may be a good thing. As long as your cells didn't reverse; it is good to drain it all the way before charging it so it doesn't develop a memeory.
Hold on tight!!!
Old 04-20-2005, 10:53 PM
302cobra's Avatar
Cobra Make, Engine: Modified DRB 2000, 302 Windsor
You can get, whats called, a Battery Stabilizer. Plug it into a wall socket and a special fitting that connects to your battery and it will keep your battery charged, over long periods of time.
HTML code is On
