SUPPORT OUR SPONSOR
Old 04-20-2005, 05:50 PM
Cobra Make, Engine: Concept, Boss351
Send a message via Yahoo to oldmachdriver
Angry seat rails
ok i admit im a bit short, 5-6 to be exact. I need a way to be able to reach the clutch without slouching. The seat thats in my contemporary isnt adjustable....did they make a adjustable seat for the driver?..and if so can anyone point me in the right direction so i can get one. My Cobra will be here on monday and id like to get an adjustable seat rail otherwise i have to figure something out....
Ne Desit Virtus
"Let Valor Not Fail"
Old 04-20-2005, 05:57 PM
DavidWard's Avatar
Cobra Make, Engine: FFR 1204 With Stack Injection
Send a message via ICQ to DavidWard
NAPA sells one, part number 825-5017. They were about $17 per set (1 seat) last year.
David
http://members3.clubphoto.com/david251117/guest-1.phtml
Old 04-20-2005, 06:21 PM
just tried to look up that part number up at NAPA websight..said it couldnt be located......any other info on it?
Ne Desit Virtus
Old 04-20-2005, 06:49 PM
Cobra Make, Engine: Lone Star, 393 Stroker, TKO 600
Take the dash out of the part number and it comes up on the Napa website. Here's the link too:
http://www.napaonline.com/cgi-bin/nc...num.d2w/report
Skip J.
Skip J.
Old 04-20-2005, 07:08 PM
Cobra Make, Engine: ERA #2097 -289FIA . 351W. PSE Torq Thrust 17" Ds. All Black.
Finish Line, Cobra Restorers, and some others also sell them (and eBay has an original set for $400). Not all will fit all "seats."
Old 04-20-2005, 07:50 PM
Cobra Make, Engine: Everett-Morrison, 428FE, glove box signed by Carroll Shelby
My wife uses a lumbar support attached to a solid pillow that pushes her 5 inches closer to the clutch. She's 5'2".
This is more of a quick fix then a permanent solution. But it is comfortable.
Chuck
Old 04-22-2005, 10:56 AM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I bought slider rails from Summit. They raise the seat about an inch. Not exactly what I wanted . But my wife and I are different sizes and she helps with the financing. But now she has had shoulder surgery and the seat hasn't been moved in a while and probably won't been moved in near future. If it is clear that you are the only one to drive your car and you are happy with the heigth ,just move the seat to fit you. If you are too low ( I've never seen too low)The seat adjuster rails will raise the seat Other concerns are how your right leg meets the tunnel? for supporting your right leg on long drives ( my right leg laid flat against the tunnel while my wifes right leg crossed at a point like a an uncomfortable edge), are you facing the pedals ? so you don't torque your knees and hip when pushing the brake and clutch pedals. How is the reach to the steering wheel and pedals ?Is the seat sitting flat on the floor so when braking you sort of slide froward out of the seat? The seat bottom needs to be tilted slightly up in front but sliders should be flat on floor.My seat was originaly bolted to floor on wood wedges.The passenger seat was bolted flat to floor. . Regular car seats, the sliders are angled but have a spring assist to help bring the seat back forward. Under braking she had to hold herself into seat by bracing her legs.I'm not that tall but I dislike the being higher.Whe going fast ,lower is better.Looks like you'll have a whole bunch of aspects to considder.
Mike H
Old 04-22-2005, 01:39 PM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
I got mine from this web site - $30.00
They ain't fancy but they work just fine!
http://www.tristatemotorsports.com/R...%20Accessories
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
HTML code is On
