Old 05-08-2005, 07:09 AM
Cobra Make, Engine: Concept, Boss351
Send a message via Yahoo to oldmachdriver
Default rear hub removal
Before i try to take this off, anyone have any guidance onhow to do this?...if I take that castle nut off am i looking at removing the whole axle?...i need to take off that hub and rplace it...the lug nut studs are all broken and stripped off in the hub. we have a jag dealer hear in savannah so iwas hopping to bring the part into them to see if they can get me another hub.
Ne Desit Virtus
"Let Valor Not Fail"
Old 05-08-2005, 08:18 AM
ok never mind i got the hub off, bearings and all, i have never worked on a jag IRS before so i was very amazed about how the rotor is up by the pumkin and not at the wheel. When i pulled the hub out 2 small Chrome rings fell off, one beveled and one small one. I need to know how these go back on the axel before i reassmeble.....is there a schematic i can use as reference?...or can someone give me guidence?....Please?....
Ne Desit Virtus
Old 05-08-2005, 09:05 AM
Tom Wells's Avatar
Yo omd,
Here's something I've frequently found useful:
ERA manual
or here:
ERA manual supplements
Tom
Old 05-08-2005, 10:43 AM
thank you that does help.....have any idea of hard it is to track down a hub?......I really want to get this car back on the road by the weekend, car show commin up.....
Ne Desit Virtus
Old 05-08-2005, 11:12 AM
Tom Wells's Avatar
Is the hub bad?
If it's the studs they are screw-in for the stock Jag hubs. The thread is the same as the outer portion - 1/2-20 if memory (?) serves. You need to grind or chisel off the staked-over area on the inner or differential side and unscrew them.
New studs are (fairly) readily available as they fit a whole bunch of years.
The hard part is re-staking the inner ends after the new studs are screwed in. Takes a pretty big press or hammer
Another possibility is to pick up a hub at a wrecking yard. I've had pretty good success with that as long as I could see them before I bought them. If you go that route, be sure to get the spacers so the bearing free play can be set correctly - as explained in the ERA manual. You may still have to buy some different thickness spacers depending on how the the hub & upright go together.
Tom
Old 05-08-2005, 02:08 PM
i dont know if the hub is bad, there are 3 lugs broken in them, and i dont have a press or anything to use to fix this, i have the hub off the car. with the bearing still on it...like i said i have very limited resources and knowledge in this stuff, but the willingness to learn. I dont have a shop to work on this kinda stuff. The hub looks like one the holes for the lug stud maybe stripped so i dont know if i should still use it. has to be someone who carries these parts. Is there a way to tell what year system it is?....number location etc etc?....
Ne Desit Virtus
Old 05-08-2005, 06:47 PM
Original Shelby Owner
You can normally drive out the lugs with a good size hammer.
