Old 05-17-2005, 08:28 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Default Front rotor wear
I have 4 piston front calipers on my ERA. I have about 1000 or so miles on the car and I am noticing the outer edge (first half inch) of the front driver-side rotor is wearing. It actually looks like it is cutting into the rotor a bit. I don't hear or feel any grinding. Any thoughts on what I should do to solve the problem?
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 05-17-2005, 10:11 PM
CSX 4027's Avatar
Default Wear
Check for loose wheel bearing
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 05-18-2005, 06:21 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Sounds like you might have a composition problem with the pad. Pull it and turn the rotor and replace the pads ( both sides ).
That or your rotor has a craftmanship problem and the Iron/steel has a very soft spot/area in the rotor.
Strange
Old 05-18-2005, 10:14 AM
joea's Avatar
Thanks guys
Old 05-20-2005, 06:24 PM
joea's Avatar
I jacked up the front end and when I spin the tire I definitely hear some brake drag. Here is a pic of the rotor...kind of looks worse in the pic than real life. There is no wear on the inner rotor surface.
I am going to pull the tire and check rotor runout. How should I check if the bearing are loose?
Old 05-20-2005, 06:28 PM
joea's Avatar
pic..
Old 05-20-2005, 06:30 PM
joea's Avatar
OK it will not accept my pic.
