SUPPORT OUR SPONSOR
Old 06-19-2005, 06:31 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Idle Temperature....
Ok, had the Cobra idling in the driveway today for a solid 60 minutes.
I have a 180 degree thermostat in the 302ci and the fan is a puller on the backside of the radiator.
She hovers between 195 and 210 degrees and 14psi for the full 60 minutes. She never got any hotter then this.
So, does this sound about right, or is she running a little too hot for idle?
I'm not busy because I did it right the third time . . .I think!
Old 06-19-2005, 07:45 PM
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Was the fan cycling? My 429 runs 190ish with the fan cycling on and off.
Old 06-20-2005, 04:21 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I had to up the fan back to the 18 inch to get the 190ish and cycling.
But, what you have sounds okay, provided the fan was cycling and it was hot outside.
Old 06-20-2005, 06:23 AM
relaxinrob's Avatar
Cobra Make, Engine: FFR Daytona Coupe done to replicate CSX-2299 at the '64 LeMans
Long idles is when it should run it's hottest, so it sounds fine.
Replicas are the highest form of flattery!
http://www.rehobothproperties.com/coupe.htm
HTML code is On
