SUPPORT OUR SPONSOR
Old 07-05-2005, 04:40 AM
Cobra Make, Engine: RUCC Cobra, 351W 400hp / 400 lbs torque
Default One wire alternator question
I have a one wire alternator, I know that the one wire runs from the alternator to the positive post on the battery. However this is my questions as silly as it may seem. I am running my positive battery cable through a kill switch, instead of running the one wire from the alternator to the positive post on the battery, I just ran it to the one side of the kill switch so it gets power when the kill switch is turned on. will this function in the same way as running it to the battery post, will it charge my battery hooked up this way? If not i assume I have to run it to the post?
Jim
Old 07-05-2005, 07:12 AM
Cobra Make, Engine: Shopping at the moment.
Jim,
You should be just fine. Just think of the other side of your kill switch as an extension of the battery post, when it is switched to on.
Chris
HTML code is On
