Old 05-09-2006, 10:24 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
Default Hey Turbo guys, anyone familiar with Snow Tech.??
Any of you oddballs running Turbo's familiar with the below listed company and their products???
http://www.snowperformance.net/
By the way, I'm in the ranks of the oddballs and considering their stage 2 cooler............................
Old 06-28-2006, 07:53 AM
Cobra Make, Engine: FFR body, lots of dreams
I've seen many of these types of systems, and they work well. However, you don't need to spend $400 to do it. I built my own alky-injection a couple years ago and ran it in my TurboCoupe. It probably cost around $60 to build.
If you want to vary the amount being injected with boost, you can just add a fuel pressure regulator.
Tadd
Old 07-13-2006, 07:30 AM
I build turbo systems for a living. I like snow kits. Things have come along way since the days of making your own however. Most use adjustable pump speeds (pressures) , a map sensor for adjustable on pressures, adjustable ramp up options, etc.
I personally run nothing but snow kits, based on availabilty. Many of the makers simply can not deliver for soem period of time. I ve never had a problem with a snow kit. I run a dual nozzle on my deisel at 65 lbs of boost, a single on my turbo (gt76) ls1 camaro, and the same on the srt4, tta,t type, and a freind even has one on his turboed zx12r.
