SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-23-2006, 12:08 PM
dsmith's Avatar
Cobra Make, Engine: ERA #63 428FE
Default changing header gaskets
Well, I made it through emissions last friday and hope to have a permanent plate on the car before the weeks end.
It has been backfiring quite a bit lately and I started wondering about my header gaskets after reading some other posts. One look and I noticed that my plugs had turned from pearly white to a shade of brown. Sure enough, the header gaskets are leakers.
Does anybody have recomendations on procedure to get the tubes off.
It is an ERA 427c with a 428 in it, individual headers. the tubes have flanges with top and bottom bolts only.
Rear cyl on driver side looks damn near impossible. Spent 1/2 hour taking 2 of the lower bolts out the other day, only to have to put them back when I couldn't do the whole job.
I have arranged access to a lift on Saturday morning and have also purchased some Fel-Pro gaskets for it. I noticed that the Fel-Pros have a four-bolt pattern, making the side walls of the gaskets very thin.
Lower bolts also look as if they will be more accessable with the car up on the lift.
Could't find any of the copper gaskets I have seen mentioned, anyone have a manufacturer or part #
Any advice, both on the gaskets and for any instillation tips would be greatly appreciated
david
HTML code is On
