SUPPORT OUR SPONSOR
Old 05-20-2006, 08:35 PM
Default Rear alignment on IRS???
Hey guys,
My new Hurricane has an IRS that's fully adjustable. Is it safe to assume that I want to align it to "neutral" 0/0/0 specs, or do I want some caster, camber, toe in it? It's a Ford 8.8.
This will be a street, not track, car if that matters.
Thanks,
Tom
Old 05-20-2006, 08:59 PM
LMH's Avatar
LMH LMH is offline
Tom
This may be a starting place: http://kms.nfshost.com/information/alignment.html
Old 05-20-2006, 09:56 PM
Hey! What are YOU doing here!?!
Old 05-20-2006, 11:22 PM
LMH's Avatar
LMH LMH is offline
I'm the wind...I'm everywhere!
Old 05-21-2006, 06:47 AM
dlampe's Avatar
My car behaves well at 1/16 toe in and about 1 degree of neg. camber. Caster is not a factor, only bumpsteer and Hurricane is as close to perfect as you are going to find. Good luck!
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 05-21-2006, 08:03 AM
wtm442's Avatar
Beam Me Up Scottie
My SPF also uses the 8.8 Thunderbird rear end.
They recommend 1/8 inch toe-in (1/4 for track)
1/4 degree negative Camber (1/2 to 3/4 for track)
Warren
HTML code is On
