Old 05-25-2006, 03:35 AM
JCoop's Avatar
Question Brake hoses stuck but good!
I got a set of steel braided brake hoses for SPF from the Olthoffs and in attempting to remove the first (RR)of the old ones, hard as I tried, the dang hose won't budge from the Wilwood caliper. I tried the RF and same thing. A wrench friend said he had encountered a few Wilwoods on custom Excursions where the fittings were epoxied onto the caliper. Anybody experience this? Is putting a torch to it the only solution?
TIA
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 05-25-2006, 04:47 PM
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
my wilwood calipers came without fittings, had to buy them separate
PapaJohn
Old 05-25-2006, 05:28 PM
Did you try just loosening the fitting from the caliper with the hose still attached?
Old 05-26-2006, 09:48 AM
JCoop's Avatar
I tried the correct open end wrench and basically rounded the fitting. Then I used a grip plier and that ate the fitting too.
I think I'll just cut the hose and use a tube wrench or a socket. If all else fails, maybe a pipe wrench will do the trick.
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 05-26-2006, 11:35 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Recently, I have received fittings that have a band of red 'LOC' around two or three threads.
After a week of use, I had to torch the metal to get the fitting to breakloose.
Perhaps you have the same situation.
May I suggest a bit of heat.
Old 05-27-2006, 06:05 PM
JCoop's Avatar
Mmmm. I guess the torch is it. Now if I can just find the flint...
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
Old 05-27-2006, 08:31 PM
be careful using a torch on aluminum, it melts at a very low temp
PapaJohn
