Old 06-03-2006, 10:37 PM
SCOBRAC's Avatar
Default parking light on all the time
My front left parking light has come on and won't shut off. The lights are off and both filiments of the bulb are lit up. The left turn sinal isn't working either (front or rear).
I have had my Contemporary 4 years and aside from a minor ground issue have had no electrical problems so I can't say this is in any way related to any systemic problem. Any Ideas?
michael
Old 06-03-2006, 11:19 PM
Check all the other lamps for filaments that have fallen out of place and shorted and grounds for bypass and backfeed, Ask yourself what has been done to the car on or about the time this all started? An errant screw or pinched harness.
Mike H
Old 06-04-2006, 03:16 AM
Yes - it sounds like feedback from a bad ground somewhere. Is there a common ground that's shared by the light and something else?
Old 06-04-2006, 04:31 AM
mrmustang's Avatar
Gold Star Contributor
Replace both the front and rear bulbs and you will be back to normal. One of the filiments has burned out and is causing this problem. Quite common on most early Fords (mustangs in my case).
Bill S.
Old 06-04-2006, 08:04 AM
Bill S.
But SCOBRAC says that his lights are on all the time, so the power source must come from outside the light circuit.
Old 06-04-2006, 12:53 PM
HighPlainsDrifter's Avatar
Default Column
Hi,
If you have a column with 4 way flashers check the flasher ckt or the flasher unit on the fuse panel also.
Perry.
Old 06-04-2006, 10:37 PM
SCOBRAC's Avatar
Thanks guys. I think you are (all) right. Nothing had been changed to cause the problem, with the exception of a long drive. I think the filiment grounding out somehow has created the problem and will change all the bulbs and the flasher unit. It should be mentioned that the left side blinkers are not working but the right side are. The blinkers on this contemporary are "hot" all the time and work whether the key is on or not. I've seen this randomly occur on various european cars and some 1960's US cars and figured it was something pretty common. Thanks again!
michael
