Old 07-18-2006, 08:17 AM
CobraEd's Avatar
Default How do I stop the flywheel from turning
OK sportsfans, I now have my RAM 13.5 lb aluminum flywheel in hand. How do I stop the flywheel from turning while loosening the old bolts during removal and while tightening the new bolts during installation??
Your answers are appreciated.
Special Ed
"It Is Not Enough That I Succeed. Everyone Else Must Fail!
________
________
Old 07-18-2006, 08:39 AM
Use an impact wrench to remove. I just find something to wedge on the block and the teeth of the wheel, then use a torque wrench.
" It ain't no big deal"
Old 07-18-2006, 08:51 AM
SCOBRAC's Avatar
If an impact isn't avaliable a an old wrench and a ball peen hammer to break the surface tension of the bolt will work. Give it a sharp wrap and it will break loose. Don't use your wifes new wrenches though.
michael
Old 07-18-2006, 09:23 AM
Clois Harlan's Avatar
I have taken two long 5/16" bolts and screwed them in about 1/2" and then I took a breakover and put it between the two bolts and then turned the flywheel until the breakover would wedge against the frame. Then loosen each bolt on the flywheel and remove the breakover. Probably not the best way to do things but it worked several times with no damage to anything.
Clois
"Let's roll"
"Be part of Something Good
Old 07-18-2006, 10:48 AM
FUNFER2's Avatar
I've just used a 2x4. Simple & won't hurt any parts.
Kevin
Old 07-18-2006, 10:55 AM
Cobra Make, Engine: 396W Kirkham KMPS036
I use a pry bar between the flywheel teeth and either the bellhousing alignment dowel pin or one of the bellhousing bolts (put the bolt back in the block). A impact wrench is the easiest.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 07-18-2006, 11:32 AM
Woodz428's Avatar
I guess I'm the only one, but I've been using a flywheel holding tool for about 20 years. It works well and fits a variety of flywheels. Available from most tool sources, although I got mine from snap-off.
WDZ
Old 07-18-2006, 11:35 AM
CobraEd's Avatar
I did a Google search on a flywheel holding tool and came up with *ZERO*
Oh well. I can just use some of the ideas above.
________
________
Old 07-18-2006, 11:55 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
You can use a "flywheel turner" and pull against it.
It is a lever type device that uses the teeth of the flywheel for turning and stopping.
Hope this helps.
Old 07-18-2006, 12:07 PM
priobe's Avatar
Why not use a breaker bar on the front pulley and loosen the bolts on the flywheel?
Old 07-18-2006, 01:25 PM
vettestr's Avatar
All the ideas are great but think funrunner hit the most basic idea. Put a wood 2x4 under the flywheel and put the least amount of pressure possible against the flywheel teeth with a pot jack or any jack.
The teeth on the flywheel or the starter ring teeth will be held from turning with mild lifting pressure. You gain advantage from the folcrum or distance from center as an added bonus. The other ideas seem good too but take another hand to hold many of the options like a prybar on ring gear teeth. GOOD LUCK
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 07-18-2006, 01:37 PM
CobraEd's Avatar
Talking
And to think, . . . I was going to fill all the cylinders with jello
Thanks guys, All good thoughts!
________
________
Old 07-18-2006, 03:13 PM
trularin's Avatar
Member of the north
I am surprised it could not be found. I have a flywheel turner for doing this and turning the engine slowly. It is a designed tool for holding the flywheel of an engine.
You say you could not find one on a google search. WOW.
Maybe I have a rarity.
Old 07-18-2006, 03:19 PM
vettestr's Avatar
No Ed ---- NO
Step away from the jello, do it now!
Save the jello and pudding for the topless wrestling. As a community service we should raise money to send the winner to get her massage license or something. Lets start interviewing ladies ASAP.
Jeff Classic
Old 07-18-2006, 03:46 PM
bill bradshaw's Avatar
Cobra Make, Engine: everett morrison 351w
flywheel turner lisle tool co part # lis23800 price 35.00
Old 07-18-2006, 04:32 PM
trularin's Avatar
Member of the north
Thank you, Bill.
I was thinking I was the only one who ever heard of this thing.
Old 07-19-2006, 07:38 PM
Cobra Make, Engine: HI-TECH 289 FIA
I use an old front wheel drive wheel bearing cut in two with the ends ground to a point to fit in the flywheel and a bolt in the block as a stop. cheap and fool proof. Repair shops usually have some laying around. I have a large collection of various sizes I use as press tools and seal installers.
fiaroadster
Old 08-02-2006, 04:28 AM
Cobra Make, Engine: ERA 427SC FMS 351W
Default How does the car drive?
CobraEd, I assume that you have installed your 13.5 flywheel, how does your car drive? What engine and transmission are you using?
Old 08-02-2006, 07:26 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Take an old exhaust valve, chuck it in your vise, and bend the stem 90 degrees. Put the stem in a bell housing mounting hole and the head into the flywheel's teeth.
Bill Stradtner
Old 08-02-2006, 09:15 AM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
summit racing has one for $19.95.
