SUPPORT OUR SPONSOR
Old 08-13-2006, 05:51 AM
Default Installing tubular control arms for stock Mustang II
I am changing stock Mustang II control arms to tubular. Installing the Speedway 1" narrowed upper and lower control arms. There is no provision for the anti-sway bar or the struts. Am I missing something here? Will I have to purchase an adaptor kit to install these or do I not need them with the tubular control arms? Any advice or suggestions will be appreciated.
Thanks in advance.
Bill
Old 08-13-2006, 06:13 AM
mickmate's Avatar
The MII arms are available in 2 common styles. One uses a strut and mount for the lower. The other adds a gusset to the back of the crossmember for the triangulated style a-arms.
mickmate
http://www.actoncustom.com/
Old 08-14-2006, 01:45 PM
Club Cobra Member
Cobra Make, Engine: NAF 427
Hi Bill. I too am installing those Speedway a-arms and you are right, there is no provision for a sway bar mount. Like a lot of things on our cars you will have to find a sway bar that might fit width wise and fab a couple of u-brackets to fasten to the lower a-arm for the link to mount to.
Once I get mine on, in the next couple of weeks, I will measure the width and start contacting, probably street rod suppliers who deal with the Mustang II front suspensions a lot and ask them if they have a sway bar for a 2" (1" per side) narrower track.
Greg
Old 05-25-2007, 06:47 PM
Default mustng II tubular a arms
I also need to get some a arm that are narrowed, but not 1". Thats too narrow for my cross member, its a classic roadster, at 1" they would hit at the top. does anyone know who makes them 1/2" to 5/8" narrowed? NOSLOW
Old 05-25-2007, 08:57 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Out of curiosity why go to narrowed A arms on a MII suspension? I could see it being used on a street/hot rod or something.
Or is it to get rid of the strut rods?
I used the Speedway MII A arms for use with the strut rods and sway bar on my car...and so far no regrets, handles quite well.
Just wanted to know the reasoning?
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 05-25-2007, 09:53 PM
mickmate's Avatar
Wheels rubbing, or worse outside fenders!
mickmate
Old 05-26-2007, 05:25 AM
I bought mine from a company called "Spartan Rod Works". They were narrowed 5/8" for extra tire width. The guy who owns the shop has a CMC Cobra, so I was reasonably confident they would work.
These arms are heavy duty. Just tell them what type of suspension you have (spring, coilover etc.) and they will build to suit. Takes about 2 weeks.
http://www.westcentralauto.com/SRW.htm
Old 05-28-2007, 11:42 AM
Club Cobra Member
I mounted the sway-bar links to the lower a-arm shock thru bolt on my Speedway lower a-arms. I just posted a couple of pics of my sway bar and link mock-up on my gallery. Take a look.
I used a MGB 7/8" front sway bar and the width, approx 36 1/4" eye to eye and with a 7" arm. Worked perfectly for my application.
Greg
HTML code is On
