SUPPORT OUR SPONSOR
Old 08-27-2006, 02:31 PM
Default what would you build
i am again looking for a Cobra to build. i have been out of the mix for a while and not really up on what is out there nowl. i am somewhat price shopping but i know you get what you pay for, and i know that there was a problem years ago with parts supply from some dealers. whit all this taken into consideration what would you sugest i look at. thanks dave
Old 08-27-2006, 03:10 PM
Hmmm,,, should I post my opinion here and risk going down in flames?
What the heck, like water off a ducks back, here goes!
Assuming your physically fit and don't require an automatic trans, not overly big and don't require a 'larger than life' Cobra replica and am not afraid to spend 'enough' to get a reasonably accurate replica....
Select a model with an accurate 'look', that even applies to the 'larger than life' models out there. For instance a Classic Roadster is a little longer and wider than the vintage cars BUT it can be made to look more correct with the right exterior appointments. Like wheels, wooden steering wheel, dash and guages (laid out in a more correct manner), single roll bar, close to original style interior, etc. Even bolt on wheels can be had in something that at least approximates the vintage look. 15" tires help a TON in this regard (over all look of the car).
If it's an FIA style car, very nice choice, try to stay close to a period correct look for THAT car. A modern small block, even a crate motor, can be made to closely approximate the look of a 289. Not much point in going with a big block in an FIA style body. Going with the classic 427 S\C body style? Do yourself a favor, stay with a Ford big block. 390, 427, 428 etc. These motors all 'look' about the same.
Top dog selection might be considered a modern CSX car from SAI, but it's pricey and unless you REALLY appreciate having that CSX vin the authenticity would be lost on you. Kirkham is always a good call for that 'authentic' look. Hard to beat ERA for a good look AND great quality. An older used replica can be an excellent choice for a really authentic build at a decent price. Hi Tech (the OLDER ones in particular) are often excrutiatingly detailed to exacting vintage specs at a nice price. Contemporary, Unique are also worth a look.
Don't care 'that much' about an authentic look (shameful, but it seems to be more common than ever around here)? There are a number of 'also rans' at a good price.
Whats REALLY important are the fundamentals:
Wheels, interior, motor selection, body style, shifter (even a five speed can have a period correct looking shifter at least). I understand the newer FFR's have improved the look of the rear end, not sure about that, but clearly it's a car that needed help in this area. Budget will be a huge factor in your search, no matter WHICH one you select it's a virtual given you WILL exceed your budget. Even if you buy a used one, that rule will apply, as it will certainly need certain modifications to fit YOUR needs. Some say a Cobra is NEVER done, and I concur, there is always something that needs to be 'tweaked'. It's one of the things that make these cars fun.
All though not currently listed for sale, mine could be had for the right dollar amount. Take a look in my gallery by clicking the camera icon. Maybe YOU don't like the black out hood I have. Figure about 500 to 600 to have it painted to match the car. THATS the kind of things you usually end up doing to a used one. Changing this or that to YOUR specs (thats what happened to me)!
Old 08-27-2006, 03:18 PM
guess i should have given more info. i am close to 6 feet tall. i do want the 90" wheel base and a close to stock appearing car. dont have to have the vin plate to make it go down the street though. i do want a 427 car and it will have the FE engine in it. hope that gives a bit more info and helps all of you guru's out there. dave
Old 08-27-2006, 03:30 PM
A number of the 90" wheel base cars can fit a close to 6' guy without a problem, some not so easy. Being able to move the SEAT back far enough is generally the key. Some cars don't have an adjustable seat. You COULD reposition the seat (drill new holes, remount) but I prefer an adjustable one. You'll be fine in a 90" wheel base in general. I'm right at 6' and do NOT have my seat all the way back! However, I like to wear the right SHOES when I drive it! Large shoes or boots (and flip flops, I'm in Hawaii after all) are all out of the question! I find a modest pair of tennis shoes works best.
I drove a slab side Aurora replica (no longer made, was from Canada) and was surprised how 'tiny' it was compared to my ERA! I assume it was made close to original specs (length\width), man those slab sides WERE small!
Old 08-27-2006, 03:59 PM
Cobra Make, Engine: ERA # 714, HD 2006 Road King Classic, several model helicopters )
Default Going fast
You might want to give Peter P a call at ERA in New Brittain CT.
I just picked up ERA number 714 from them and I cannot tell you how great they have been so far. I am 6 feet 1, 250 lbs and they made sure the fit was there. They go out of their way to help and yet make sure you end up with a kit that has great re-sale value as it is so true to the original.
I had an aluminum block FE 427 built from Danbury Perfromance Engines and that has also been an equally great experience.
I am still putting things together, but the guys at ERA have been doing this so well for so long they really have it down. My two cents.
David Orr
Good luck!!
HTML code is On
