SUPPORT OUR SPONSOR
December 2025
Old 10-07-2006, 10:15 PM
double ugly's Avatar
Default fuel gage vs: fuel cell
Can fuel gages be semi accurate when using a fuel cell? I have a Fuel Safe cell and the gage when full is slightly above 1/4 and when empty is slightly below 1/4. Really usefull. I was told that the sending unit on the top of the cell container can be "tweeked" so it will show accurate readings. True or False? I would really appreciate most any input.
John
double ugly
Old 10-08-2006, 05:40 AM
See Centroid products for Fuel Safe
Old 10-08-2006, 05:42 AM
Tommy's Avatar
I run a fuel gauge sender in my fuel cell with no problem. As the fuel cell is filled with foam for safety, the sender probe is a long tube rather than a float used in ordinary fuel tanks. You also need to have a sender that is matched with your guage electrically (for example, 240 ohms empty, 33 ohms full).
Tommy
Previously owned EM Cobra
Old 10-09-2006, 12:17 AM
Cobra Make, Engine: HI-TECH 289 FIA
The Centroid sender I installed is dead on. However I have a 289. Its gas tank is way different than an original style 427. A 427 tank is so weirdly shaped and installed that I wonder if any sender would work well.
fiaroadster
HTML code is On
