SUPPORT OUR SPONSOR
Old 11-18-2006, 01:19 PM
Default Electric Choke Wiring
I'm running a 750 Holley with an electric choke. There are 2 terminals coming off of the electric choke. One is a ground terminal that is grounded to the carburetor and the other appears to be the power source terminal.
My questions is where to attach the power source? I have a 1-wire 60 amp alternator that has a terminal with the positive wire off of the battery attached to it. Can I share this terminal with the choke power feed?
Old 11-18-2006, 01:26 PM
wtm442's Avatar
Beam Me Up Scottie
Hot can come from any switched source. Power to choke only when key is in the ON position, otherwise you will slowly drain the battery.
Warren
Old 11-19-2006, 02:25 PM
Cobra Make, Engine: West Coast, 533 BB Ford
The + wire on the electric choke should be hooked up to the
"S" (stator) terminal on the alternator. This way the electric
choke only receives power when the engine is running.
Gerry
Old 11-19-2006, 04:44 PM
Ibr8k4vetts's Avatar
I hooked mine to the coil
Mike Z
Old 11-19-2006, 04:50 PM
wtm442's Avatar
Beam Me Up Scottie
edited do to a massive brain fart .....
Warren
Old 11-19-2006, 05:33 PM
MaSnaka's Avatar
The choke plate closes when the accelerator is pumped. Electricity warms the coil on the side of the choke that slowly opens the choke plate up and keeps it open. The power supply should be switched to off when the engine is turned off.
HTML code is On
