February 2026
Old 01-27-2007, 09:09 AM
Olddog, an interesting idea. I think the plumbing would be a nightmare however. And the fittings for a typical 'heat exchanger' type radiator I'm afraid would be to small. Trans oil is certainly much 'thinner' and considerably less volume than engine oil requirements. An oil T-Stat would be better.
Old 01-27-2007, 09:18 AM
I'm sure that the heat exchanger and fittings would have to be propperly sized for the oil and flow. Certainly the ones used for an auto tranny would not work. Perhaps the T-stat is the better solution.
Old 01-27-2007, 09:21 AM
Originally Posted by olddog
I'm sure that the heat exchanger and fittings would have to be propperly sized for the oil and flow. Certainly the ones used for an auto tranning would not work. Perhaps the T-stat is the better solution.
Radiators with built in heat exchangers for oil are quite common. It would replace your oil-to-air cooler.
Old 01-28-2007, 08:32 PM
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
Summit sells this Earls oil thermostat. It uses -10 O ring fittings for the in and out ports.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
