SUPPORT OUR SPONSOR
February 2026
Old 02-03-2007, 09:37 AM
Cobra Make, Engine: CSX4000, 427
Default How significant does acceleration affect fuel distribution and HP?
I was wondering about all this talk about dyno HP, but it's not a true enviroment of racing, and one of these multiple aspects involves G-force, and its affect on fuel distribution in the intake manifold. I was told that with NASCAR, when the cars are under high cornering G-force, there can/is substantial alterations in fuel distribution, which I would think affect HP.
With drag racing in a normally aspirated car, , with acceleration, there is obviously some G-force with acceleration. In a 11 sec 1/4 mile car, would there be significant fuel distribution changes that occur as opposed with running the engine on a dyno? Is there a difference between single and dual plane intakes?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 02-03-2007, 09:54 AM
Cobra Make, Engine: Cutting Edge, Boss 429
I'm not too sure that there is significant fuel distribution problems w/ an 11 sec. carbuerated car, but it does make a pretty good argument for port fuel injection if in fact there is significant power loss.
Old 02-03-2007, 11:08 AM
And if not an 11 sec car, what about a 10 sec, 9 sec, etc.
Old 02-03-2007, 11:18 AM
I don't know about the atomized fuel after the carb, but I can tell you it can cause problems in the carb fuel bowl. Under large G forces the fuel can all run to one side of the bowl and uncover the jets, and it results in fuel starvation. Some carbs have baffles to prevent this - other solutions as well.
At the London car show last year there was a fellow that was having this problem. He would launch and the engine would stumble bad. Second gear was a slight stumble, and then it was ok. He ran over and over again. I wanted to suggest he try raising the float level, but never got the chance.
HTML code is On
