02-24-2007, 12:07 PM
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Can I switch to synthetic Oil?
Question:
Can I switch to 15w 50 synthetic oil in my engine?
I have been using 20w 50 in my 302 for over a year. Is there any reason I can't drain the 20w 50 and switch to a synthetic? Appreciate the time and comments of all who answer.
Jerry
02-24-2007, 12:24 PM
Beam Me Up Scottie
MA
As long as there is 5000 miles on motor, I see no problem. But that is a little heavy for NY area. Maybe 10-40 would be better. That's what I use. With 15-50 weight it will take a loooooooooooooooooong time to warm up the oil. Been there ... done that....
Warren
02-24-2007, 01:08 PM
Thanks Warren,
I don't have 5,000 on the motor yet. My main reason for switching to synthetic is to reduce start up wear on the motor.
Jerry
02-24-2007, 01:30 PM
Beam Me Up Scottie
MA
Originally Posted by jerry w
Thanks Warren,
To reduce start up wear, you would be better off with a Morose Accusump or equivalent. Many synthetic oil mnfgs recommend 5K miles with regular oil b/4 switching to synthetic. Just my 0.02 cents worth.
Warren
02-27-2007, 01:36 PM
mo
put it in a new engine your rings wont seat can you say blooooooww by did it to our racer@I70speedway boy were my competitors behind me ticked as they were wiping it off ther cars after the races.hehe ooops
02-27-2007, 01:56 PM
Stolen Avitar
GA
I agree on the ring seating. But that should only take a hundred miles or less these days. Any time after that the synthetic should be fine. I run 15w50 Mobile 1 and have had very good luck with it. It's also worth mentioning that the newer 15w50 Mobile 1 has increased zinc content for those of us still hung up on flat tappet cams.
Steve
02-27-2007, 02:12 PM
I put the synthetic stuff in my 331 cu in race motor after it has been dynoed....which is about an hour of running time......no blowby and no problems so far, I run regular oil in my street car..........
DAVID GAGNARD
02-27-2007, 04:41 PM
Thanks Guys!
Appreciate your experience and knowledge.
Regards
Jerry
02-27-2007, 06:28 PM
Jim Woodard
